Kirjoittaja Aihe: HobbyWing Platinum 130 HV V4  (Luettu 6177 kertaa)
Poissa HeliFlyFinland
  • Moderator
« : 05 Huhtikuu, 2016, 15:04:20 »
Hinta : 280 €
tuotteet Suomessa noin 16.4 .2016
Excellent Motor Speed Governing
High-performance 32-bit processor combined with advanced algorithm makes the motor speed-governing excellent for different conditions. With the adjustable sensitivity of speed-governing, every pilot can find the most suitable settings for his helicopter.
Super Soft Start-up
The ESC makes the motor start extremely soft and avoids tail-drift issues of helicopter.The start-up time is adjustable within 8 to 25 seconds, this will definitely create a perfect starting point for every flight.
Super BEC
The built-in switch mode BEC with a continuously adjustable output voltage, range from 5V to 8V(step: 0.1V). It is certain to put out the power you need for rapid, precise steering servo operation.
DEO Technology
The DEO (Driving Efficiency Optimization, or so called "Active Freewheeling") technology implemented in the ESC has multiple advantages.
 ● Quicker response to the throttle change.
 ● Higher driving efficiency, longer flight time.
 ● Lower ESC temperature and a more reliable operation.
Four Brake Modes
The ESC has “Brake Disabled, Normal Brake, Proportional Brake and Reverse Brake” four brake modes. The brake amount is adjustable in normal brake mode; in proportional brake mode, the brake force will be automatically allocated based on the position of the radio throttle stick; in reverse brake mode, the motor rotation can be changed via a spare transmitter channel.
Multiple Protections
Multiple protection features include ESC thermal, capacitor thermal (HOBBYWING-patented technology), ESC overload, throttle signal loss (or Fail Safe), and low voltage cutoff effectively prolongs the service life of the ESC.
Other Features
A separate programming port for connecting the programmer on the ESC allows user to:
 ● Program ESC,
 ● check flight data include minimum voltage, maximum temperature, standardized RPM and speed curve (in Heli Governing Store mode) of the flight data recorded by the ESC,
 ● Upgrade ESC firmware
 With a multifunction LCD program box or a Wi-Fi Module & our Apple/Android phone App
« Viimeksi muokattu: 07 Huhtikuu, 2016, 06:16:15 kirjoittanut HeliFlyFinland »
  • Moderator
Vs: HobbyWing Platinum 130 HV V4
« Vastaus #1 : 10 Huhtikuu, 2016, 06:58:13 »
Viivästys toimituksessa
uudet 130 tulee suomeen vasta 28 .4
Poissa Hayabusa
« Vastaus #2 : 06 Toukokuu, 2016, 17:19:29 »
Nyt saatavilla , onpa kevyt ja laadukkaan oloinen juttu
« Vastaus #3 : 06 Toukokuu, 2016, 17:27:05 »
Saisko kuvan jossa vierekkäin 160A kanssa?
  • Moderator
« Vastaus #4 : 06 Toukokuu, 2016, 21:39:15 »
sorry en voi avata pakkauksia
oheiset kuvat varmaan auttaa hahmottelemaan
Poissa Hayabusa
« Vastaus #5 : 07 Toukokuu, 2016, 11:10:44 »
Koko vertailu normi servoon
11436 Lukukerrat
Uusin viesti 05 Joulukuu, 2015, 17:27:01
kirjoittanut Kallo
35 Vastauksia
32248 Lukukerrat
Uusin viesti 22 Maaliskuu, 2016, 10:53:44
kirjoittanut Koippa
57 Vastauksia
52273 Lukukerrat
Uusin viesti 23 Tammikuu, 2017, 22:11:09
kirjoittanut Konna
12720 Lukukerrat
Uusin viesti 16 Tammikuu, 2016, 08:01:37
kirjoittanut calicha92
7106 Lukukerrat
Uusin viesti 21 Syyskuu, 2016, 14:08:48
kirjoittanut R3DgRu
