Kirjoittaja Aihe: Espoo(henttaa..)  (Luettu 618946 kertaa)
Poissa Affen
  • Niilo Koivunen
Vs: Espoo(henttaa..)
« Vastaus #125 : 15 Toukokuu, 2008, 15:07:45 »
Tässä Hyvinkään kupeessa oli maa ihan valkoinen. Huvittavan näköistä...
Poissa Karkkis
  • Markku Kärkkäinen RC-Kopterit Ry
« Vastaus #126 : 15 Toukokuu, 2008, 15:09:31 »
Mä taidan tulla kanssa kattomaan et kiertäskö noi sadepilvet henttaan ohi :-\
T-Rex 600NSP
T-Rex 600E PRO
T-Rex 250
« Vastaus #127 : 15 Toukokuu, 2008, 15:17:58 »
I'll fly it for a while, it seems to be quite fuel efficient (Joni already commented that it must be too lean since it eats so little fuel, but the needle setting seems to be on the edge where it works at all).
My main concern is that it drops out in flight, my autos are still a bit flaky, as proven on Sunday. Also, there is still too much water in Hentta  ::)
still continuing.
Then again motor was very cool. I was thinking that you used too much collective pitch in break in phase when there is still not power. Because of not enough power yeat "Booooooooooo..." happened.
But comparared to my OS that is VERY fuel economical.  :D
Edit: Olen paikalla sää varauksella 17:30 -->
Edit2: Sataa, joten tarkkailen tilannetta. Tänään on kuitenkin tarkoitus lennättämään päästä
« Viimeksi muokattu: 15 Toukokuu, 2008, 17:36:09 kirjoittanut Maikko »
« Vastaus #128 : 15 Toukokuu, 2008, 22:14:50 »
Allright, the hotter plug was clearly the way to go, at least for the time being.
Joni set up the heli, and it flies very nicely now, and very accurately (thanks again!)
Later, the muffler came loose. What should I say? I had been warned this would happen, had seen this happen myself (although for different reasons), now it happened to me.
Well, fortunately the heli still flies without the muffler, which came back dangling from the pressure hose. Probably no amount of threadlock will keep this in place, it gets too hot.
Gotta get longer screws and double nuts.
« Viimeksi muokattu: 15 Toukokuu, 2008, 23:42:44 kirjoittanut mnentwig »
Poissa jaska.t
« Vastaus #129 : 16 Toukokuu, 2008, 17:04:39 »
No niin kentälle on hyvä keli.
« Vastaus #130 : 16 Toukokuu, 2008, 17:27:39 »
jesh.
« Vastaus #131 : 16 Toukokuu, 2008, 17:29:32 »
Täytyy tulla.
Poissa MJPilot
« Vastaus #132 : 16 Toukokuu, 2008, 19:54:53 »
If you need help to tune the TT engine I have some experience on tuning different engines, inc. the tt50.
It,s not as bad as everyone says it is, just the carb is more of a plane carb than heli version.
Rest of the engine is very nicely in tolerance.
Do a search on TT 50 pro needle mod in google and youll get the engine running just as good as Os and others.
People dont know how to fine tune 2 stroke engines, and get it wrong, suddenly all of those brand engines are crap  ???
Every engine can be tuned, some need more work than others, just a point of view.
MJP
Trex 500 ESP kait?
MJP-Rex 450
« Vastaus #133 : 16 Toukokuu, 2008, 21:16:07 »
Hi,
many thanks for the info! I almost contacted you, but tried a hotter glowplug first. Afterwards it was running quite OK, and it doesn't die in mid-flight anymore (I hate it when that happens...)
I'll try the needle mod, apparently it fixes exactly the problem I was experiencing, namely that it dies when I take off the glowplug starter because it runs too rich at idle.
Here is a link with some pictures, if anybody else is interested. http://www.runryder.com/helicopter/t70888p1/?highlight=tt50+needle
I guess part of the problem was that the Raptor kit shipped without glowplug. I tried OS #8 first, according to the manual, and it didn't work too well. Now with the A3, it's OK. Probably I'll try the #8 later, when it's broken in and I have tapered the needle.
Poissa MJPilot
« Vastaus #134 : 16 Toukokuu, 2008, 21:30:00 »
No prob.
Just a reminder on 2 stroke basics, take care not to lean the engine too much when running hot plugs, accidentaly or on purpose.
And allways use fuelfilter, cos if the engine gets lean the hot plug will melt the piston.
Hotter the plug more advanced is the point of ignition, and more heat is created.
MJP
Trex 500 ESP kait?
MJP-Rex 450
seppomikael
« Vastaus #135 : 17 Toukokuu, 2008, 17:16:57 »
Minä olen tulossa.
Saat minulta myös opastuksen kentälle.
Poissa Arctikdiver
  • Jari Salin RC-Kopterit Ry
« Vastaus #136 : 18 Toukokuu, 2008, 12:38:01 »
Miten on olisko muita menijöitä...
Tommin kanssa juteltiin, kun tuo sadekin lakkas, niin vois mennä opetteleen.
Läskillä on aina lämmin
Miehen voi saada Lapista, muttei Lappia voi saada miehestä. -Lordi-
Poissa jaska.t
« Vastaus #137 : 20 Toukokuu, 2008, 16:35:03 »
Onkos tänään ketään tulossa.
Poissa Arctikdiver
« Vastaus #138 : 20 Toukokuu, 2008, 17:40:13 »
Lähden juuri töistä tulemaan...
Poissa Hondamies Hessu
« Vastaus #139 : 20 Toukokuu, 2008, 22:48:10 »
Olen ihan uusi Henttaan kävijä. Löysin heliporukan sattumalta pari viikkoa sitten Suurpellosta. Olen ihan aloittelija lennätyksessä. Rakentamisessa en ole ihan aloittelija.
Alkoi huolestuttaa kun Henttaalla vissiin alkaa tehorakentaminen ihan justiinsa. Tänään panivat puita nurin.
Pitäisiköhän ottaa yhteyttä Espoon kaupunkiin, että antaisivat jonkun "joutomaan" tämän harrastuksen käyttöön?. On niitä annettu turhempaankin, tai ainakin halvempaan harrastukseen. Ei sinne "joutomaalle" tarvisisi tehdä kiinteitä rakennelmia kunhan vaan olisi joku 5 x 5 metriä tasainen alue josta nousta ja johon laskeutua jos osaa.
En vielä tunne tätä Henttaan porukkaa juurikaan enkä tiedä jos jotain tiedusteluja tai suunnitelmia on vaikkapa jo tehtykin uuden paikan löytämiseksi.
Hondamies
SPEKTRUM DX7 Radio (2kpl)
AR7000 Rx (2kpl)
AR9000 Rx (1kpl)
AR6000 Rx (1kpl)
TREX600E (2kpl) Helicommand 3D (2kpl) Scale Fuselage Eurocopter AS550 "Fennec" for 50Size heli Three Blade Flybarless Head Helicommand RIGID EagleTree eLogger V3 (2kpl) EagleTree telemetry w Seagull Dashboard and 2.4GHz EagleTree sensors: temp, servo current, pack current, altitude, air speed etc PHOENIX-RC Sim  Onkohan tämä se "olemisen sietämätön keveys"? Saattapa ollakin mutta mitäs tuommoisesta riekkum
Poissa jaska.t
« Vastaus #140 : 21 Toukokuu, 2008, 08:27:11 »
Olen ollut espoon kaupunkiin yhteydessä.Silloin sanoivat että ämmänsuolle
tulisi jossain vaiheessa pienkenttä sanoivat että pitää tehdä kaava muutos.
Jos jollain on haluja voisihan sinne taas soitella.Kyllä espoolla,on joutomaata
vaikka kuinka paljon.
Poissa Niko.v
  • RC-KOPTERIT RY #177
« Vastaus #141 : 02 Kesäkuu, 2008, 20:04:15 »
Terve kaikille.
Missäpäin tämä kenttä sijaitsee? Olen töissä viikot vantaalla joten voisin tulla sinneppäin lentelemään.
Ps. Ja ei se säätöapu pahitteeksi olisi :)
T-rex 600N, T-rex 600N Pro, T-rex 500esp, Hirobo SDX, Blade mSR,
RC-KOPTERIT RY #177
Poissa Halfelf
« Vastaus #142 : 02 Kesäkuu, 2008, 21:22:09 »
Tuossa keskustelussa on mukana kartta paikan päälle. En ole itse siellä käynyt mutta oletan että ne on tossa kartasa näkyvät pellot + keskustelussa on tarkempaa ohjeistusta.
http://www.kopterit.net/index.php?topic=1258.0
« Viimeksi muokattu: 02 Kesäkuu, 2008, 22:01:39 kirjoittanut Halfelf »
Poissa Karkkis
« Vastaus #143 : 03 Kesäkuu, 2008, 07:25:03 »
Terve tuloa vaan.. eli tuolta se löytyy..
Maamerkkinä toimii iso puinen kuutio joka näkyy kehä kakkoselle, siinä kuution luona ollaan koptereita lennätetty!
T-Rex 600NSP
T-Rex 600E PRO
T-Rex 250
Poissa jaska.t
« Vastaus #144 : 06 Kesäkuu, 2008, 21:19:52 »
Tänään en päässyt.Mites huomenna.
Itse aijon mennä.Pitää koittaa vanhusta
taas ilmaan.Pistäkää jotain kellon aikoja.
Poissa pasisalminen
« Vastaus #145 : 06 Kesäkuu, 2008, 23:44:21 »
Tere,
Tässä parit testikuvat Henttaalta.
ps. Kyllä sinne katolle vois ehkä ländätä. Ihan tasainen se näyttää olevan :)
Poissa Jyri
  • Jyri Laitinen - Valokuvaaja
« Vastaus #146 : 07 Kesäkuu, 2008, 14:13:39 »
Onko tänään illalla kukaan menossa Henttaalle lennättämään, ajattelin että tälläinen aloittelija voisi tulla katsomaan konkareiden lennätystä...
Poissa tubelius
  • Tuomo Kämäräinen
« Vastaus #147 : 07 Kesäkuu, 2008, 22:08:40 »
Olihan sielä koko päivän porukkaa, ei vaan kerkee forumille kun lennellään. Aina on vapaapäivinä porukkaa kun sää sallii. Mukaan vaan!
Poissa Jyri
« Vastaus #148 : 08 Kesäkuu, 2008, 21:08:30 »
Mihin aikaan siellä yleensä on ihmiset lennättämässä, tässä muutaman kerran ohi ajaessa Kehältä katsoessa en ole ikinä onnistunut näkemään siellä ketään?
« Vastaus #149 : 08 Kesäkuu, 2008, 21:13:31 »
Kyllä siellä tänäänkin oli porukkaa seitsemän aikaa illalla kun ohi ajoin. Eilen oli ollut kanssa.
6422 Lukukerrat
Uusin viesti 25 Syyskuu, 2012, 15:19:01
kirjoittanut eriks
140 Vastauksia
71071 Lukukerrat
Uusin viesti 14 Joulukuu, 2014, 10:30:44
kirjoittanut Hayabusa
33218 Lukukerrat
Uusin viesti 04 Maaliskuu, 2021, 21:05:06
kirjoittanut Gemmi
5175 Lukukerrat
Uusin viesti 29 Huhtikuu, 2015, 19:54:05
kirjoittanut patse
6046 Lukukerrat
Uusin viesti 31 Elokuu, 2015, 10:18:33
kirjoittanut Tomppa_1
