Kirjoittaja Aihe: flying gloves  (Luettu 22991 kertaa)
flying gloves
« : 04 Joulukuu, 2010, 13:32:36 »
I guess it's the first "flying winter" for many on this forum, and this may be useful:
simple cloth gloves, from the gas station, for €2.
It takes some time to get used to flying with gloves, but at some point you simply forget about them.
Vs: flying gloves
« Vastaus #1 : 04 Joulukuu, 2010, 16:08:23 »
ite koitin kanssa sellasilla työhanskoilla joissa sellanen keinonahkamainen kämmenpuoli <- ihan hirveetä ei pysty!
sitte leikkasin peukut pois ja koitin uudestaan <- edelleen ihan hirveetä ku peukku ei pääse liikkumaan ihan vapaasti hanskan kiristäessä >:(
tässä taas tulee se ku on aikanaan ruvennu peukuttaa ohjainta eikä lennä puristusotteella! miksei alottelevaa Tohtoria joskus neuvottu että "opettele käyttämään puristusotetta!"  >:( <-ärsyttää!
loppuis noi sormien lipsahtelut tikuilta! >:(
Vs: flying gloves
« Vastaus #2 : 04 Joulukuu, 2010, 16:35:42 »
Maybe I'm even guilty of trying to convert some beginners to pinch grip. But all too often it's received as the kind of "yeah yeah let him talk" advice no one wants to hear when thumbs are so comfortable.
I'm not even sure if thumbs are any worse with gloves. Don't give up too easily, it may take many flights to  get used to it, but I'm sure it'll earn the pilot more confidence for next summer.
BTW:
>>miksei
The "why" is actually quite an interesting question. My answer: most people on web forums are beginners, consensus is made by the majority. Most "forum flyers" fly thumbs. Not sure about Hentta.
At least I think twice before stating something in disagreement with the consensus - more often than not it's an exercise in futility:
"Yes", I've got an opinion about RTF helis for beginners. But "no", I keep it to myself, most of the time.
I remember some heated discussion about gyros on rc-heli.de. After several days it slowly became clear that the local "guru" with 4000 post hadn't even learned backwards flying. What a monumental waste of time...
Anyway, getting OT here.
Tuhannen pisteen turvahanskat!  :P
I got 1000 points? Wow! Now what am I going to do with them...  :)
« Viimeksi muokattu: 04 Joulukuu, 2010, 17:00:51 kirjoittanut mnentwig »
Poissa Jerkku
  • Rc-Kopterit Ry
Vs: flying gloves
« Vastaus #3 : 04 Joulukuu, 2010, 17:37:51 »
Mulla ainakin ohuehkot kangasselkäiset keinonahkaisilla kämmenpuolilla varustetut duunarihanskat on toiminu ihan jees, leikkasin tosin peukun ja etusormen pois, ei ne erityisen lämpimät ole mutta kyllä niillä aina akullisen kerrallaan lentää, hanskojen tulee vaan olla riittävän isot.
Peukkuote/puristusote taitaa lukeutua tämän foorumin ikuisuuskysymyksiin, ite lennätän peukuilla ihan siitä syystä että junnuna autopuolella tikkuradiolla oppinut tuon tyylin ja että nakit on niin kankeat ettei puristusotteella pysty ;) En tiedä olisinko tämän parempi lennättäjä jos oisin aikoinaan puristusotteella opetellut lennättämään, taitaa olla ainakin meikäläisen kohdalla ihan muista asioista kiinni...
Tippa pikaliimaa korjannee tuon lipsahteluongelman  ;D ;D ;D
« Viimeksi muokattu: 04 Joulukuu, 2010, 17:39:41 kirjoittanut Jerkku »
Trex 500 ESP  3G
Vs: flying gloves
« Vastaus #4 : 04 Joulukuu, 2010, 18:24:04 »
Itsekkin olen monet hanskat kokeillut eikä niillä oikein pääse hyvälle tuntumalle, paksuilla on lämmin mutta ei voi lentää, ohuet on kylmät mutta tuntuma on ok... lähetin huppu on se ratkaisu varmasti.
Vs: flying gloves
« Vastaus #5 : 16 Helmikuu, 2011, 10:31:15 »
Idän ihmeiden kaasulla toimiva säteilylämppäri on ainoa kesätuntuman tuoja;)
Vs: flying gloves
« Vastaus #6 : 21 Helmikuu, 2011, 20:57:26 »
I'm not saying I'm flying much... but mine are literally worn through on four fingers   ;D
Poissa Picofly
  • FPV rocks!
Vs: flying gloves
« Vastaus #7 : 21 Helmikuu, 2011, 21:39:00 »
Kerrospukeutuminen on hyvä käytäntö myös käsineiden suhteen. Kaksi ohuempaa kerrosta toimii pakkasella paremmin kuin yksi paksu.
Kokeilin viime talvena aika monet käsineet ja parhaaksi osoittautuivat Hestran ohuet tuultapitävät alussormikkaat joiden päälle vedän lämpimät villakynsikkäät. Yhdistelmä pitää sormet notkeina vielä -20 asteen pakkasessa jos vaatetus on muutoin kunnossa (kokeiltu on monta kertaa). Nollasään tuntumassa käytän apteekin puuvillaisia alussormikkaita ja niiden päällä vuorettomia pyöräilykynsikkäitä. Apteekin alussormikkaat ovat kuivana ok mutta jäähtyvät heti jos pääsevät yhtään kastumaan.
Yleensä kaverit kommentoivat ettei tuntuma hansikkaiden kanssa ole sama kuin ilman. Onhan se alkuun totta, mutta sopivilla käsineillä eroa ei parin lentokerran jälkeen edes huomaa. Ohuiden aluskäsineiden & kynsikkäiden etu lähetinhuppuun verrattuna on se ettei käsineitä ei tarvitse riisua käsistä missään vaiheessa koko lennätyssession aikana. Olen viime talvena jopa vaihtanut Gaui EP200:n pääakselin sormikkaita riisumatta  :D.
« Viimeksi muokattu: 21 Helmikuu, 2011, 21:41:01 kirjoittanut Picofly »
Vs: flying gloves
« Vastaus #8 : 21 Helmikuu, 2011, 21:42:01 »
Totta,
Itsekkin vielä pystyy hyvin lennättämään jos on ohuet hanksat + kynsikkäät (jos pitäisi lämpimänä). mutta jos on yhtään paksummat hanskat niin tuntuma katoaa totaalisesti... en tiedä miten toimisi jos paksuihin hanskoihin tekisi tikuille reijät, ja niiden sisällä ohuet hanskat ettei alumiinitiku palelluta sormea  ::)
Poissa Noxi
Vs: flying gloves
« Vastaus #9 : 21 Helmikuu, 2011, 21:55:21 »
Ai tämmöset?  :)
Tosin alushanskoista on peukut pois ja sillon tuulella palelee. Pitäs kokeilla auttaako jos pitää ne ehjänä ja poistaa hiukan tuntumaa :) Nuo apteekin hanskat ei kyllä tuulta pidä... Mutta ei oo nyt yli -10 asteen pakkasilla ees tullu lennättämään lähettyä niin tarkenee noilla.
            T8FG Super
hankar
Vs: flying gloves
« Vastaus #10 : 11 Joulukuu, 2012, 15:53:42 »
Juu, vanha on viestiketju, mutta talvi tulee taas/ on jo! Onkos nämä transmitter glovet ja vastaavat mistään kotoisin? Turnigyn versio aiheesta.
Eli onko nuo huonoja, vai ei ole ollut tarjolla tai tiedossa jolloin ei vain ole käyttökokemusta?
Toinen tulkinta samasta aiheesta:
Olihan noita jo muuallakin ihmetelty, eli eipä tuonut tämä viesti mitään lisäarvoa mihinkään suuntaan  :o
« Viimeksi muokattu: 11 Joulukuu, 2012, 16:22:35 kirjoittanut hankar »
Re: flying gloves
« Vastaus #11 : 11 Joulukuu, 2012, 17:33:09 »
Toi malli on kaikilla käytössä https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=11738
Ja toi lämmittimenä sisällä.. https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14858  Tosin custom ohjaimella. Tuolla protopajassa juttua siitä
Vs: flying gloves
« Vastaus #12 : 11 Joulukuu, 2012, 17:38:11 »
tärkeintä ainakin omasta mielestäni on se että pussin on tarpeeksi korkea. muuten kädet osuu pussiin ylhäältä ja häiritsee. toi juuson laittama vanha turnigypussukka on loistava hieman rujosta olemuksesta huolimatta! sähkölämmitys tosiaan tarvitaan jos kovilla pakkasilla meinaa lentää.   ;)
5049 Lukukerrat
Uusin viesti 04 Marraskuu, 2009, 11:38:16
kirjoittanut Kallio
4530 Lukukerrat
Uusin viesti 09 Marraskuu, 2009, 00:27:14
kirjoittanut finFlyer
4461 Lukukerrat
Uusin viesti 11 Kesäkuu, 2011, 20:41:40
kirjoittanut Trnquill
5571 Lukukerrat
Uusin viesti 14 Joulukuu, 2012, 09:03:35
kirjoittanut jkkmobile
4375 Lukukerrat
Uusin viesti 26 Lokakuu, 2015, 10:46:37
kirjoittanut Johny
