Kirjoittaja Aihe: Spartan Vortex VX1e  (Luettu 45290 kertaa)
Vs: Spartan Vortex VX1e
« Vastaus #25 : 22 Syyskuu, 2015, 18:57:26 »
No perskeles, mikä jottei
« Vastaus #26 : 25 Marraskuu, 2015, 06:38:31 »
V4 julkaistu:
* Built in support for 3+ blade helicopters. Although it was still possible to fly 3 blade helis before the new firmware offers targeted refinements for multi blades helicopters, eliminates guesswork and offers excellent performance out of the box.
* Fly your speed heli flat out without touching the cyclic and it will track like an arrow. The new Speed Mode is activated when Style is set to 100%. As usual some tweaking of gains is also required for speed runs. We will produce an FAQ in due course.
* All new tail gyro firmware offers 46% improvement in piro consistency and tail hold in hard punch-outs. The tail tracks better in backwards flight.
* New electric governor with soft-start and auto bailout. Holds RPM tighter than any gov we know of. It's dual preemptive response will harvest the very last bit of power from your power system. Discover power you didn't know it existed.
* New Gasser governor mode is an evolution of existing nitro governor which now takes into account the torque curve of Gasser engines.
If you have Spartan Studio already installed simply hit the Sync button and you are ready for V4. The V3 menus will continue to work just fine when a Vortex with V3 firmware is connected to the computer.
151124 M6
Severity: Significant performance and functionality updates. Non critical bug fix.
Studio: Click Sync to update
DataPod: 4v00
VX1 Flight Computer: 4v00
VX1 Remote Sensor: 4v00
VX1n Flybarless: 4v00
VX1e Flybarless: 4v00
* Added electric and gasser modes to governor.
* Added soft start option for electric helis.
* Governor gains are now adjustable individually in each flight mode
* Updated DataPod and Studio UI to support higher RPM range for small electric models
* Added live rotor RPM in System::Stats
* Added smooth activation of cyclic and collective to throttle mixes. Mixes now run only
when the governor runs.
* Removed MixOnly governor mode as mixes now only run when governor is operating.
* Improvements to NVM access to account for voltage drops outside the operating voltage
range.
* Added support for Spektrum packet id 0xA2 produced by some newer radios.
* Minor bug fix to the servo PWM module.
* Added throttle and pitch curves to Vortex and DataPod.
* Brand new tail gyro system with significant improvements in piro consistency and hold.
* Failsafe now operates in SV5 (Vortex output) so it accounts for internal mixes and
throttle curves. Previously it worked on receiver throttle.
* New sensor calibration mechanism. You can now power on the heli whilst holding it on
your hands. Calibration will commence when the Vortex detects no motion and will
restart each time it is moved.
* Specific 2,3,4,5+ blade support by control loop and heli wizard.
* Heli Wizard readjusted for 180 size helis.
* Added speed mode. Activated when Style is set to 100%. Specific tuning of other
parameters is also required. TBA
* Cyclic Rate has been removed from Rotor menu as it causes confusion with Agility.
* Auto Abort Expo has been removed from Gov menu and it now operates on its previous
default value of 30%.
« Vastaus #27 : 31 Joulukuu, 2015, 16:00:10 »
Nyt kun tuosta Neosta on puhuttu jo liikaakin, niin muutama sana tuosta spartanista.
Lentotuntuma on aivan älyttömän hyvä. Käytäytyy juuri kuin simu, mutta tietty oikee on oikee. Gyro on super lukittuneen tuntoinen ja tuntuu kuin olisi paljon tarkempi kuin vbar silverline tai mini. Oon siis käyttänyt tuota 500 protoksessa ja se ei tee mitään ylimääräistä. Esim peräedellä invertedympyrää voi vetää niin lujaa kun tikuista lähtee ja kone on erittäin herkkä edellenkin ohjattavuudeltaan, en sano etteikö vbari olisi, mutta mini ei kovassa vauhdissa käyttäydy noin solidisi.
Softapuoli on todella helppo ja sain suoraan pöytäsäädöillä toimimaan hyvin. 2 kertaa olen läppärillä gaineja säätänyt ja täts it. Govia en ole vielä testannut, mutta näyttäis softan puolesta olevan helpomi kuin vbarin säätö. Ajattelin tehdä videon, missä käyn tuon säätämisen läpi. Mulla menee Graupnerin gr16:sta yksi kaapeli gyrolle missä kulkee udi protokollalla kaikki kanavat ym... helppoa eikös juu. Sähkön govin koitan heti kun kotiudutaan reissusta. Softa on tehty etittäin simppeliksi, mutta ns. expert valikoita löytyy paljonki, itse en ole tarvinut niitä säädellä. Ainut miinus on asetusten tallettaminen tai kopiointi, kumpaakaan ei ainakaan vielä voi tehdä ja kaikki säädöt on tehtävä firmispäivitysten jälkeen uudestaan. No ei iso homma, mutta homma kuitennii. Freakistä lueskelin, että asetusten tallennus olisi mahdollisesti tuloillaan. Hyvin tulee päivityksiä ja kehittävät koko ajan softaa.
Kaikenkaikkiaan erittäin hyvä ellei parempi vaihtoehto esim. neolle.
« Vastaus #28 : 31 Joulukuu, 2015, 18:21:59 »
Eipä noita asetuksia yleensä joudu tekemään uusiksi firmispäivitysten jälkeen, tämä V3 -> V4 oli poikkeus.
« Vastaus #29 : 11 Helmikuu, 2016, 17:17:15 »
Spartanin Jeti integraatio on valmis ja ladattavissa Spartanin sivuilta: http://www.spartan-rc.com/products/vx1e/vx1e.php?p=5
« Vastaus #30 : 11 Helmikuu, 2016, 20:19:27 »
Filut ladattu koneelle ja ei kun päivittämään:)
2*VX1e
1*VX1 Pro
« Vastaus #31 : 11 Helmikuu, 2016, 21:21:04 »
Vortex filu ladattu radioon, VX1e+datapod ladattu 4.50 versiolla.
Testattu Rsat2 vastarilla EXbus asetuksella ja konffattu Datapodilla VX1e käyttämään EXbussia Setup valikosta.
Zägäng Jetillä loppu setuppi:)
Testattu toimivaksi
Loistavaa työtä Angelokselta.
Mee likes
PS.
Testasin myös REX7 vastarilla, ei toimi Spartanin (UDI ja EXBus protokollilla) kanssa ennen kuin Jeti julkaisee 1.02 firmiksen vastariin jos silloinkaan...
« Vastaus #32 : 11 Helmikuu, 2016, 21:33:39 »
Missä portissa koitit?
« Vastaus #33 : 11 Helmikuu, 2016, 21:42:43 »
Tero
REX:n peräänkö kyselet?
6,7,EXT
UDI,EXbus testattu porteissa6&7
PPM tuossa toimii, mutta en sitä halua.
Spartan Vortex VX1e
« Vastaus #34 : 11 Helmikuu, 2016, 21:49:59 »
Ex Bus ei eroa datana oli se sit R tai REX, siks toi ihmetyttää. Varmin veto olis se EXT-portti. Mitä sulla oli ajotuksena REXin kanssa?
« Vastaus #35 : 11 Helmikuu, 2016, 22:28:55 »
G380 kopussa on Rex7+mui100+rpm-AC sensorit, yge90v2 nopari ei taida tukea Jlogia.
Muuten tuo RSat2 olis passeli, mut ole sille exp2:ta.
Samppa
« Vastaus #36 : 25 Toukokuu, 2016, 09:31:30 »
Spartankin saamassa tärinälogit, ensimmäisenä tuki VX1n ja VX1e malleille.
Beta versio ladattavissa: http://www.spartan-rc.com/pub/vortex_beta/vibration_analisys_tool_beta_160525AM.zip
Edit: ei beta, vaan demo
« Viimeksi muokattu: 25 Toukokuu, 2016, 15:43:33 kirjoittanut njs »
6977 Lukukerrat
Uusin viesti 15 Elokuu, 2014, 10:22:40
kirjoittanut njs
3322 Lukukerrat
Uusin viesti 18 Joulukuu, 2012, 12:48:56
kirjoittanut Dje
15196 Lukukerrat
Uusin viesti 30 Heinäkuu, 2016, 12:45:16
kirjoittanut jesi
7475 Lukukerrat
Uusin viesti 17 Toukokuu, 2015, 14:18:24
kirjoittanut jkkmobile
ImmersionRC Vortex
Aloittaja seOjala Multikopterit
5284 Lukukerrat
Uusin viesti 16 Syyskuu, 2015, 23:21:09
kirjoittanut seOjala
